I have a MTD Pro Snow Thrower 31AE6LFH718 and have taken apart the auger assembly. When I removed the auger gear box, it seems to have the remnants of a gasket between the left side (Housing, Auger, LH Reduced) and the right side (Housing, Auger, RH Reduced) ? I've tried finding the part number, but I can't find that there is a gasket on the diagram.
Does a gasket exist for this model?
See diagram on page 24 at http://manuals.mtdproducts.com/manuals/769-01275b.pdf and choosing "Chute Assembly"
Attached are two pictures, one of the auger gear box before I disassembled it and another of the decal displaying the model and serial number.
Thank You!
I had no idea that MTD had a Professional Shop Manual available for their snowblowers. Mine isn't quite as robust as the ones being talked about here, but they share similarities. I'll have to see if I can find one for mine.
The sealant around the auger gearbox in my blower has started to peel away as well, so your findings are quite helpful.
