I have an MTD 31AE150-062 single stage snow blower. Belt broke on me yesterday trying to clean the 14"+ we got here in SE Michigan Sunday.
I bought a new 1/2 X 35 belt and put it on - no problems.
Unfortunately, when I went to test everything out I noticed the belt flapping loudly against the cover. I then noticed that the auger was spinning, even without the handle engaged.
When I pull the handle, everything seems to work fine.
Disengaged, the thing rattles like crazy and auger doesn't stop.
Anyone have any ideas? Is there an adjustment I can make? Is it possible the idler spring needs replaced?
My blower is pretty old, but has been very reliable.
Any suggestions are greatly appreciated.
Thanks!
hello jimmy, welcome to SBF!! all my single stage experience is with toro's. that said if a toro belt was making noise inside the cover it would be either too big or routed wrong through the tension pulley
Thanks for the reply William.
I was wondering about the belt length. I did not buy an OE belt - just a generic one from my local hardware. I checked the routing to my manual - seems like it all matches.
Maybe I will need to order the OE belt and see if it is any better...
Jim
Jim
if you can get the OE belt at a dealer take the after market belt with you and then you'll know right then and there if its too long, good luck jim
i had that issue on my toro 824 38080 two stage after i replaced the belt, you just have to let the belt wear in for about 30 minutes, if the issue doesnt just go away then adjust the idler pulley
Picked up an OE belt tonight. Definitely a little tighter. Issue went away. Guess it pays sometimes to go with OE parts.
