I recently purchased my first snowblower, a 1971 Jacobsen Imperial 26 Heavy Duty Two Stage blower. Model/SN is 52624-2056.
I'm currently looking for a parts manual. I've found manuals for the more common 52638/40/42 but they are slightly different - they have two belts, one for drive and one for the auger, mine has a single belt.
The previous owner welded one auger to the rhs drive shaft - nice. Once I grind the welds, what's the best way to replace the auger? Can I remove the rhs drive shaft through the side of the housing once the end bearing is removed or does the entire auger/gearbox assembly etc get pulled forward from the front?
Thanks, Tom
I think you will have to crack it in half and remove the shaft and gears along with it. Don't be surprised if things are seized onto the shafts though - unless the PO was in the habit of greasing things. (Not my kind of luck!) Good luck Tom! SHould make a nice solid machine once you get er going......
:welcome: to the forum Tom. Looks to have a newer model 8 hp?? Tecumseh engine on it along with newer snow hog tires. Good luck with the repairs.
Nice to see another Jacobsen owner. Sorry it's fighting you.
We love a good project with photos. Take some photos of that nuts welding so we can give you our best guess.
Just purchased 52624 w serial 7426. U said yours was a 1971? Do u know what mine is? Looks like a good machine. Id post a pic but cant yet. Need more posts. Lol. Have you got yours up and running?
