1 - 20 of 20 Posts
No,thats it.I added the headlight.It`s a new one on me too.I`m thinking the brand got bought up by another company. The stripping is similar to yard works...
I picked up new belts but for now she`s doing well.It`s one of the first I saw with a partial drive shaft;that your drive/tension wheel slides on...
Interesting to see the labels in both French and English. That could be a hint. Maybe European? Or just a local store rebrand? The chute looks MTDish.
IMG_5527.JPG And if you`ll notice,when you engage the augers,there`s a rod to lift the auger brake,but I think there might be a spring missing because when the brake engaged the augers still turn.I noticed at night with the cover off,tiny sparks come from it.Maybe the metal wedge is worn down to much...
On the bucket? It's just a rust spot above the h. It's "phases", same as phases in English, another word for stages.
I found out from my sources that this snow blower is from a distant planet from the Alpha Centuri star system.
quite valuable , by the way . but only to Alpha Centurians.
Yup, because their snow is different, made of frozen helium crystals and with 13 sides per flake instead of 6.
My guess is also an MTD clone. My 10/32 Craftsman looks almost identical. It is an MTD from 1983. Only the handlebars are different. Mine has flapper arms.
Reactions: orangputeh
is there a model or serial number on it lance and what about the serial number for the engine
^ them darn left handed cigarettes will get you every time ! ^
1 - 20 of 20 Posts
