1 - 20 of 31 Posts
My 13 year old 22 inch, 5hp yard machine kept stalling and could only throw the slushy wet snow 3 feet. As I watched my neighbor with his Ariens deluxe 27 with 10.5 hp throw the snow a good 20 feet, my machine was stalled out and could not start. I did not give up hope. As I pulled the recoil to get it started, the pull cord broke. I may keep this machine as a project to fix the pull cord and replace the auger belts, However, I am absolutely getting a new machine. so I am looking for opinions on the best machine under and up to $1500.
Thanks in advance,
Yard Man
You'll have a nice blower if you spend that much. Ariens or Toro are your best choices. Read Scot's page on blowers here http://www.snowblowerforum.com/forum/general-snowblower-discussion/1364-made-usa-versus-made-china.html
Lots of people prefer to buy locally from a dealer so they have support in case of problems. Also if you're not mechanically adept the dealer will have it set up properly. Big box stores seem to have better prices bit not always. It pays to do your homework before buying. One other thing to consider is do you need that much blower? Consider driveway/sidewalk size and snow placement before buying. Also consider the EOD situation. If your driveway is one car wide and 50' long you'd have overkill buying a big machine. Do your homework and ask us questions.
Finally, if you know what to look for you can get a really good deal from craigslist. Happy shopping!
I just finished cleaning the slushy wet snow we had and was very happy with the performance of my Ariens 921038 Platinum SHO 24" ;)
You can use a higher gear and pack the heavy snow/water in and throw it farther :D and the engine power is great :)
Lastly you can always' try'this modification. Trust me if you install it properly it does a fantastic job in improving blower performance. SNOWBLOWER IMPELLER KIT
...I am looking for opinions on the best machine under and up to $1500.
Here's another angle: I don't know where you live, but around here $1500 would get you a nice older more powerful used machine on Craigslist, another nice older more powerful used machine as a spare, and you'd still have $500+ left in your pocket for beer money! :cool:
Thanks in advance,
Yard Man
the snow ice slush sleet we got last night, IMHO, you don't use a snowblower on that. you use a plow.
I plowed it out of the way today with the 16HP Briggs powered tractor. it was like plowing concrete and it even hardened like concrete where the plow left it.
snowblowers were never designed to throw heavy wet slush, they'll do it but none of them will go it as well as a plow.
buy a tractor for those occasions, use it to cut the grass, then when you get a slush sleet mix like we got last night, bolt the plow on and go.
Thanks in advance,
Yard Man
Hey.. That's exactly what happened to mine too... Only choice is to use the electric start.
I will replace the cord in the recoil starter this summer and rebuild the machine for my dad. Sounds like your machine needs a impeller clearance kit so that it can throw the wet snow/sludh. I will do this to mine too.
As I suggested in your other thread, based on your budget I would consider Ariens Deluxe 24, Deluxe 28, Platinum 30 or Platinum 24 SHO.
All are at different price points, but within your $1500 budget. You would need to decide if the bigger size or extra power is worth it for you.
Cheers,
Stuart
Yeah, I am frustrated. Maybe some of those other machines are overkill. All of you bring up really good points. The best point is that snowblower were not designed to move this slush. Ariens 24 deluxe would probably do the trick for me. I am having a hard time finding good pricing for the 24 deluxe. Ariens does not put MSRP on its website. Any thoughts on a good price range for the Ariens deluxe 24?
i used the 2450E on the snow / ice mix yesterday, no clogging and i can see pavement
Outdoor Power will delver a machine to your door set up ;)
Product Categories Snow Blowers Archive - Outdoor Power, LLC
Inventory and selection is at it's lowest point right now. If you can hold off until the fall, that would be your best bet if shopping for new. The new Ariens machines will start hitting the showrooms in July/August. That's when you'll get to see, in person, side by side, all the latest models. There may even be some new models for the 2015/2016 season.
Slush
I am going to try this, I wanna break machine down repaint lube and install an impeller kit. My blower never shut down but kept getting clogged up so much that I wound up shoveling and it was really heavy wished blower was able to do the job for me,maybe next year after modifications. 😄
I am going to try this, I wanna break machine down repaint lube and install an impeller kit. My blower never shut down but kept getting clogged up so much that I wound up shoveling and it was really heavy wished blower was able to do the job for me,maybe next year after modifications. ��
I posted on the Impeller kit thread yesterday my first test in wet snow, plus sleet, plus freezing rain in the amount of 2 to 3 inches. No clogs and threw the slushy mess plenty far enough. It is a great upgrade.
I bought an Ariens 24 Deluxe in Valparaiso Indiana for $1060, set up and out the door. This was in November 2014. The Deluxe 28 with the 254cc engine was the same price.
At my local dealer, both the Deluxe 24 and Deluxe 28 are listed at $999, HD carries the Deluxe 28 for the same price.
If it's not rusted out I'd repower it for about a hundred bucks. If it has rust and the metal is thin... time for a replacement machine indeed.
1 - 20 of 31 Posts
