1 - 3 of 3 Posts
Hi Tim, and welcome to the group. If you're not having luck through Sears, you might try someplace like Tractor Supply, or Farm & Fleet, or a small engine repair shop. Stores like that will probably carry pulleys of different sizes and configurations.
Only one I found online was on ebay and guy wanted $50 for it + $5 shipping.
Do you know the dimensions of it? The guy on ebay said 3/4" shaft, but doesn't give the diameters.
Is there enough room on the engine to use 2 single pulleys? You can get 2 single pulleys that fit a 3/4" shaft for much cheaper most likely unless you can get a good deal on a used one.
Here is a good site to look for new ones:
Pulleys & Idlers | MFG Supply
Their categories are confusing though, best to look through them all and see what matches your needs. The "Steel V-Belt Pulleys" would be the cheapest, but some of the other categories include odd sizes.
Also, as was mentioned above, Tractor Supply Company has some and they are a local store if you have one in your area.
1 - 3 of 3 Posts
