Hi,
I am having a lot of trouble with my engine.
a little history... last winter everything was going well but the carb got gunked up and so i ordered a new carb three months ago(same price as a rebuild kit) but it didn't work. My engine with the old carb would surge and not idle (common). with the new carb it won't rev up as it supposed to and will backfire/ flood somehow.
So as people suggested i checked valve clearance and everything around, changed spark plug, removed the head cleaned everything off to no avail.
so i checked the new carb and noticed that the welch plug inside the bowl was missing.
So i ordered another carb, still no welch plug. Tried the new carb and it does the same thing but i was able to adjust it somehow but now the governor arm pushes the throttle to idle to maintain a somewhat low operating rpm (it blows snow but the throttle is at idle so I can't idle the engine down and it's obviously not right).
So my guesses are:
1-somehow i didn't put the linkages to the right hole on the throttle arm when i put the engine back together?
2- i bent the governor linkage?
3- the governor is bad?
4- i really don't know what is happening
the picture was taken while the engine wasn't running you can see the throttle is opened , there is resistance if i try to push it to idle .
If someone can help please i would be grateful
So my guesses are:
