It's silver and says "Arctic" and "32" Width" and that's it. I was able to find that it has a Bolens logo on it. There are no other identifying remarks, I'm not even sure what HP the Tecumseh motor is.
I picked this one up a couple of years ago for parts and finally got around to tinkering with it today. When I picked it up from the garbage pile the owner and his teenage son laughed at me, HA!
I put some gas in it today and hit the electric start and after a bit it cranked over and ran like a champ even though it hasn't been run in at least two years. The auger spins like it should. What it doesn't do is self propel for more than a few inches.
Any help in identifying what model it is so I can look up parts would be great. I originally got it because it looks just like a John Deere 32 inch I have that needed a motor, but I found a 9.5 hp Tecumseh off a Craftsman blower I'm going to put on. I'd like to get this one up and running as well.
Is that metal shavings in the pan?
When you say propels for a few inches? Meaning the machine moves forward only a few inches? or the auger only turns slightly?
Could be anything from adjustment, broken spring, bad friction disc, broken gear, missing/ broke roll pin, bad belt, etc, etc.....
Should be easy enough to diagnose.
BTW, those look like grade 5 bolts in the Augers, not shear pins ... might want to check the augers for rust weld, as well as the auger gear box for damage, as well as proper lube conditions in it.
I would imagine those were branded units built for large retail outlets back in the day by probably by Murray, MTD or the likes of such.
Some metal shavings. Although I think it is from the bottom pan. The pan is bent in a bit and it looks like the chain on the gear has rubbed through (and had a patch welded) over it. It looks like there should be a bit of a curve to the pan but that there is currently too much, or a bit of a flaw in manufacturing... well bear looking at more.
The machine only moves forward (or back) a few inches. The auger spins well.
I looked at the friction wheel and the plate it pushes against. The friction wheel seems to have a fair bit of play side to side when not against the plate. There are also some chunks of rubber missing, and both are really greasy. I'll try cleaning off the grease and see if that helps.
I've been looking at some videos and the forums to learn more. I do know an old guy (80 or so) who works on snowblowers and such, not as much anymore but I can still pick his brain and be the hands :)
Rust weld, will have to look that up. And I'll check the "shear pins" to make sure they're pins and not bolts. I just put my friend's motor on an old snowblower I had that the engine seized on, his father-in-law used bolts instead of shear pins and bent the auger shaft. My friend didn't want to take the time to do the auger shaft himself so I swapped the motor out for him.
I have a bit of a clue when it comes to these things, I can muddle my way through but it's as much because I like tinkering and figuring out and hate spending money.
