1 - 11 of 11 Posts
after getting a free CCR Powerlite a few weeks ago, I just found a free CCR 2000 in the neighborhood. PO said it hasn't been used in couple of years. Model 38180. Didn't look up the year yet.
Very nice! My manly side wants a Powershift. In reality nice single stages like those are really the way to go! Amazing what gets tossed this time of year.
congrats, may it serve you well
Nice find, I'm still using mine - got it in 1994. If its got the Suzuki engine in it, you're in good shape.
thanks all. I'll update how it runs in a few days, need to finish up a few other projects first.
Got to look at the CCR 2000 today. The metal side panels have a bit of rust, may clean those up and paint. Paddles are worn, but will wait to see how the engine runs before spending any $ on that. I removed the Mikuni carburetor, doesn't look too bad. Will clean and hopefully re-use everything but the bowl gasket and bowl nut gasket.
Thanks.
I got the CCR 2000 carburetor back on today, along with new fuel lines and a filter. Started up pretty easy. Running at around 3720 rpm. Did notice that I had to prime the carb to start, even if warm. But runs smooth. Its a shame the rest of the machine is kinda beat up. For now I will leave as is, and see how it runs in the snow next season.
Priming the carb is not unusual.
Just a tip, Check the primer hose for leaks and how the primer bulb is working.
I've had mine since the late 80's, for storms up to 4 inches or so, it's what I use the most.
One of the classic single stage blowers.
Thanks guys. I had reseated the primer hose fitting into the carb, it had come loose during disassembly. Primer works well, I can (now) tell when a primer is functioning properly. One prime and one pull. Like I had mentioned earlier, the rest of the machine will need some $ to work well (paddles, scraper, maybe belt). And I've got several (well, more than that) functioning machines already. I will leave this one as is for now, maybe I'll find a good unit with a bad motor.
i wouldnt bother running the machine of the paddles and scraper are bad. the performance will be awful.
its the #1 thing needed for a SS blower to perform well.
1 - 11 of 11 Posts
