Hi all, new here, and just bought a craftsman blower. It is a Husqvarna made blower with the 291 cc LCT engine. Ran fine when I bought it. Got home tonight, it fired right up, went to blow snow, made it 10 ft and quit. Pulled it back to garage, fill tank with fuel, put a heat gun on the carb, thinking it may be a little froze, and started up again. Ran for 15 secs quit and won't start again. So, I pulled the oil dip stick, and the oil came flying out, thin, and mixed with gas. I am not a mechanic, but can do normal maintenance stuff. So, what is this? Is my motor blown? Do I take it back to where I got it? Or can I fix it? Input would be great, thanks,
Kevin
change the oil and fix the carb, sounds like the float needle isnt shutting off the fuel. with any luck your engine will be ok.
Ok, will give this a go in the morning. Are the carbs complicated? Had carbs off sleds and quads and bikes apart before, done the basics, jets, carb cleaner, etc. I usually run seafoam in everything I own. I did crank this machine over with the electric start a bit trying to get it to go. Hopefully no harm done! Thanks for your input
if you just bought this blower from sears take it back, don't do anything. let them fix or replace it
the carb is as basic as it gets......take pics of the linkages tho.
+1 on taking it back in its current state & condition (crankcase still full of fuel.)
I'd insist that they replace due to wear-and-tear on the engine from insufficient lubrication.
It is not a new blower, I bought it used. Should I be concerned about damage to piston, sleeve and rings
You will probably be ok. Just drain and re fill with a good 5w-30 oil. Take the pictures as recommended. Those carbs can be a bit of a paint to get off. the plastic shielding is a real pain.
