1 - 3 of 3 Posts
I have a older MTD that doesn't move forward or reverse, I have replaced the drive belt and tightened the cable, the friction wheel appears to be ok also. Any suggestion of something else to try
Have you tried putting it in service position, and then remove the belly pan and then turn the wheels by hand to watch what happens versus what should be happening. It is a fairly simple system to follow. Donyboy has videos that explain its operation.
1 - 3 of 3 Posts
