I picked it up relatively cheaply today because it had a seized engine, but I am hoping it is seized up due to inactivity and not engine failure.
It came with the 4-lug 8" wheels/electric starter.
This will probably be a long-term project for next winter. I have dumped quite a bit of PB Blaster in the combustion chamber and I *think* it wants to turn. I'll probably wait a couple of days before turning the starter cup nut.
The previous owner stored it outside under a tarp and the throttle control cable was seized and the auger lever was also seized. I was able to free up the auger lever and the throttle control cable will be sourced cheaply enough.
If I can't free up the engine, I'll probably go the Predator route again(the engine mounting studs are already long enough and the chute crank rod with u-joints appear to be more accomodating than the 10000 series).
I'll take better pictures once I start the project, but here's the as-is photo:
