Do you have good spark?i would like to sell some of these as is to people, but haven't had any luck with postings. i do think engines do well ($200-$300?) on ebay; otherwise, it is exhausting trying to part stuff out.
the snow-tek is in very nice shape. so mild rust, but was definitely stored indoors. two questions: are other rim/tire combos swappable for these tubeless tiny rim wonders? and, couldn't get any engine action yet. found the primer bulb rotted. did a temp swap, but just got gas pouring out of the carb. plug was wet. is the primer bulb just for drawing fuel into the carb? no return line like on a 2 cycle? even with a wet plug, zero ignition. new carb time?
If not, try a different spark plug or could be a bad coil.
Do you have decent compression?
With fresh fuel down the hole or starting fluid in the carb, spark and compression, the engine should at least sputter a few times.
