The Googleizer makes it appear like it is a Annovi Reverberi D22291 2,600 Max PSI Gas Pressure Washer Oil Lubricated Pump.
Reactions: db130 and CarlB
As mentioned, Google a little more with the info you have, which looks like everything is on that label ......
You can get replacement pumps starting just under 100 to over 300.00 .... you might get lucky and find one that bolts up for cheap.
I have seen plenty with ruined pumps where people don't use the conditioner/anti-freeze fluid in the off-use storage and ruin the pump.
