1 - 1 of 1 Posts
Hi -
Found this old Jacobsen Imperial 26 at the house I'm renting. It was obviously missing a spark plug wire, but I soon found out it didn't have any of the magneto unit behind the flywheel.
I found a used magneto and installed it yesterday. I have been able to pull start it fine.
I believe the carburetor has been replaced, but there is nothing on the air intake side - no push spring like I've seen on some Imperials and no primer bulb - just open. Do I need to put something on there? The cover for that area is missing as well so there is nothing keeping snow, etc. from getting sucked in. As well, after I shut the machine off a bit of wispy smoke comes out of there. And lastly, today soon after I shut it off some fuel started dribbling down out of the intake.
And if you've read this far, how can I get more info on the impeller kit I've read is a must have?
Casey
1 - 1 of 1 Posts
