Just got in from my first blow of the year - didnt challenge the 621 at all. I was getting quite a bit of undersnow(snow shooting underneath to form a snowrow), is that plastic scraper supposed to be adjusted to prevent that?
hello heykoolaid, welcome to SBF. i don't think the scraper bar on toro single stage blowers are adjustable
It could be the shape of your driveway. If it is V shaped and you are going right down the middle there will be a low spot. Try going sideways or just off center.
its pretty much every pass, up or down, sidewalk, driveway. Probably has an hour or so of run time on it, so wear is not an issue. Have to do some close inspection(face on ground, engine not running and see if I can see a gap or something)
are you pushing the blower or letting the paddles pull it
What Detrbuzzard and Shryp said. Let your machine do the work and there should be no problem.
if you are pushing the machine the scraper bar isn't in contact withthe ground causing the blowback of snow you are getting
