1 - 3 of 3 Posts
Two Questions from a newbie.
1. What are those two pieces of flat stock that stick up from the auger housing on some of the machines?
2. Will I cause damage to my machine if I help my neighbor with his gravel driveway?
1. drift cutters, used to cut into high drifts of snow and knock it down.
2. YES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i use a snowblower on a gravel driveway
you can use a snowblower on a gravel driveway if;
1-- the driveway is in very good shape and very flat. (no ruts, bumps, potholes etc.)
2-- the skids on your blower are adjusted to keep the snowblower about an inch and a half to two inches off the ground.
if its not your driveway and you dont know every inch of it you shouldnt do it.
i wouldnt and i am used to using one a gravel driveway
1 - 3 of 3 Posts
