I'm currently rebuilding a 1971 sno thro, disassembled everything, cleaned everything thoroughly, inspected and replacing parts where needed. I was noticing the parts are in pretty good condition especially for its age with very little rust that easily cleaned off. Im thinking i did too good of a job in cleaning everything by removing all the oil and grease that was most likely protecting the metal from rusting.
I want to keep everything clean looking but also want to protect from rust. Things like the disc bracket to me look like it came originally coated in an oil film, and i just cleaned it all off. I used steel wool and dish wash soap on everything.
My thoughts are coating things like the disc bracket, gears, sprocket, even the chain with fluid film when reinstalling, just a light film coating. I just received the new thrust bearing and didn't realize they don't come greased so I'm off to Lowes to get some red and tacky grease, figured id use this grease on the hex and sliding fork shaft also. The only things i will keep clean are the friction wheel and the drive plate.
Any other ideas, what have others done when rebuilding these parts?
