I was thinking that but the gas tank is plastic and hear they are hard to paint properly so they resist gas. Even though its not the original engine i would like to keep it looking original.I know it's not the original engine, but if you are planning on repainting the engine and tins anyway, why not go with a Canvas white.
Give the machine the original Creamsicle look.
If you take a look under the bolt head you may see a few lines left over from the bolt making process as these bolts may well be made with a split die, because of their length. The ribs under the head if present will split a hardened washer. If you use a softer washer this wont happen but it will affect your torque values a bit.I was thinking that but the gas tank is plastic and hear they are hard to paint properly so they resist gas. Even though its not the original engine i would like to keep it looking original.
I have some HF epoxy paint I tried on the underside of a cover and it doesnt hide anything well, I sanded everything down pretty good but the paints so thin you can see every imperfection so i'm going to try Krylon high heat satin paint I read good reviews on. $7 a can. Too bad because that HF paint is very durable.
I was cleaning the head bolts and the washers started splitting in pieces. Odd because three of them broke and there are 2 washers on 3 of the bolts, wonder if they were the bottom ones when installed. I couldnt find the exact same size but hopefully they are close enough to work. There is a piece on the engine that I cant find on the parts diagram, goes on top of the cover over the head. It cleaned up nicely though.
I ended up peeling off the stickers because there were rust bubbles and wrinkled paint under all of them except the serial number which I kept. Your 1st photo is exactly what I was looking for, I'm going to copy that on mine. There was a sticker on the top of the shroud for the electric starter but the plug ended up covering it so no need to bother with that. I also picked up a tachometer like the one you have.Looking great, you are doing a fantastic job.
I would mask off the stickers, but correct stickers might be found here:
My 69 Ariens was a complete repaint, so I masked off all the stickers before priming and painting.
