1 - 20 of 25 Posts
Hello everybody
I was wondering which gasoline did you use in your snowblower, regular or higher octane? the dealer told me to use high octane gasoline to avoid engine pinging. yet, I use in my lawn mower john deere regular gas to which I add stabilizer. I never had a problemwith any engines I own. I always empty tanks and carburettors at the end of the season and everything starts without problems with a minimum of maintenance. what do you think?
Seems like you answered your own question. You know how to take care of your equipment. I don't subscribe to super unleaded in OPE. We are not dealing with high compression turbo charged engines here. As you said regular 87 octane gasoline with a good stabilizer like Star Tron or Marine Stabil, you should be fine.
If it's not a high compression engine and the manual doesn't state to only use premium, then stick with regular. In my area however, I cannot get regular gasoline without ethanol anymore, so I do use premium.
Like Cardo111 said, these are not high-compression, high-performance engines. There is no reason for the engine to be pinging. Regular 87-octane is fine.
Using stabilizer, and emptying the carbs at the end of the season, is an excellent idea, however, and is a simple investment in keeping your machines happy.
Edit- As drmerdp said below, I'm assuming we're talking about 4-stroke blower engines. I do use 91 octane in my 2-stroke chainsaw, per its manual (which calls for at least 89, maybe 91).
Only exception are 2 cycle engines. I would use 91 or 93oct.
I use 89 octane ethanol free gas. Ethanol is corrosive to carb parts.
Download the Pure Gas app. You can find where to buy it. Usually near/at marinas.
I use it it all my yard equipment. I will use stabil towards the end of the season.
I agree with Mike above. Here in the Buffalo, N.Y. area, I have access only to 91 octane ethanol free gas - which I use, thanks to wise folks here at Snowblower forum. Absolutely no regrets!
A buddy of mine Just brought me 10 gallons of ethanol free 91 from his sledding trip. I won’t start using it until later in the season though.
I store my HSS with a full tank, and a drained carb.
when we had zero degree weather around here for 4-5 straight days , every gas station pump in town was froze up except one......
Chevron.
so we use Chevron with stabil and seafoam.
nada problems.
And the vast majority will never see issues with using fuel with ethanol in it. I use 85/87 Octane with ethanol and my personal equipment has never had any issues. Been using it for about 20-25 years since they started putting the stuff in the gas. Although for the past few years I have been using Stabil-360 as a stabilizer and it supposedly helps with ethanol that is in fuels.
using ethanol is not the issue, letting it sit idle in the carb for months is.
i bought 91 eth free as a precaution and cheap ins
I use 91 octane with seafoam and have no issues.
I love my snow pups, I wish I still had all four of them.
That is so true.
Most 2 cycles are high compression and require at least mid-grade.
more like high test for a 2 stroker. they have more compression than most think, and fixed timing so they need the slower burning HT blends 91 or 93
4 stroke ope engines run 9 to 1 or lower, have fixed timing making 87 good enough when one adds stabilizer
I run whatever the highest octane I can buy at a regular pump is. Here we have 87/89/91 with 91 being ethanol free so I go with that.
1 - 20 of 25 Posts
