1 - 11 of 11 Posts
Folks, I have several Deere's that I'll be refurbishing as time permits. What is the best way to go about getting the correct paint for these? Just get a scraping of current color on the rigs and take it into a paint store to have it color matched? Some are all green, some are green & yellow.
Thanks
They have a lot of farm colors at my local Tractor Supply company. You should see if there's one of those in your area . They have the International Harvester/Farmall red and some other truck and tractor companies I would think they would have John Deere colors too. Give them a try :cool: be sure and use the compatible primer to the paint you buy.
Probably both. And there is a Tractor Supply not too far from here so I'll need to swing by. Thanks for the advice.
Naah no overspray. Sand down.. do it right.
That's not what overspray is :confused: , I'm sure POWERSHIFT will get a bang out of that :cool: In all seriousness though, but you'll be OK because I used an IH Red ( closest to Toro red match they had, matched fairly well) rattle can from Tractor Supply on mine, it had a newer fan type nozzle and did a pretty good job. :cool:
Go to Harbor freight, but $13 paint gun, then go to the local Deere store buy 1 qt of JD Paint and JD thinner, follow mixing directions, paint and enjoy!
If you don't have a compressor, I would use genuine JD rattle cans. Several on My Tractor Forum have had great success with JD's rattle cans.
Ryan, East of the MN tundra, no "eek" using Rustoleum Farm paint cans.;)
Nice Job on the restoration. I enjoy a good restoration thread. I like to paint and I would like to get into painting some more albeit with an air compressor and paint gun rather than the spray bombs I work with. I like to work with my hands with my Hobbies. I do my own maintenance on my snowmobiles and snow blowers and boat and watercraft. Nice example of an older 1989 John Deere snow blower you got there
1 - 11 of 11 Posts
