I've posted a few questions recently about paint and parts for my HS828. So now comes one about dealing with the rusted impeller housing, chute, and auger housing. Over the years, if you blow the EOD ice and snow thrown into your drive by your municipalities snow plows, the salt will attack the steel and rust and pit the metal.
What techniques have you guys found to be successful in bringing the machine back to life?
Is sanding the old rust off enough? I can try Locktite's Extend and then paint on top of that. Or, have you tried filling the pits with bondo and the sanding it smooth before you paint.
I happen to have some Ospho rust remover from a motorcycle restoration. I'll use that first after some sanding, and then paint. However, any way I slice it, this is going to require a lot of elbow grease - there is simply no way to take power sanding tools to the many nooks and crannies of the machine (even with the various parts stripped down on my work bench).
