1 - 20 of 23 Posts
· Registered
Anyone have problems reusing the U spring nuts on the housing after removing the housing to grease ? I got frustrated and just replaced them with u speed nuts.
seems they had sprung and couldn’t get them to line up. Never used spring nuts before so not sure if they are a one time deal.
· Registered
They take a beating down there. Anything that makes the job easier is A-OK with me.
· Registered
Discussion Starter · #5 ·
· Registered
Discussion Starter · #6 ·
Can anyone tell me the Ariens part number? I’m looking at an exploded view but cannot locate the part. Want to see what they call it
looking for an 2020 Ariens Platinum 24
· Registered
Discussion Starter · #8 ·
The part holds the bolts to attach the back cover which is removed for greasing. This part should be the same on all recent models but it’s a Platinum SHO 24 bought new a couple yrs ago.
· Registered
Discussion Starter · #14 ·
Thanks. I have speed u nuts which are basically the same but don’t require threading and are easily reused. Never heard these called retainer nuts. The threaded version we always called spring u nuts
· Registered
My parts manual calls them "nut, retainer, .25 - 20 × .56". My p/n is also #07009000. I've never had a problem reusing mine.
· Registered
Discussion Starter · #18 ·
· Registered
Discussion Starter · #20 ·
I coat them in grease. I would try the threaded but this was my first experience with threaded and 2 of OEM I couldn't reuse as they wouldn't line up and the speed nuts I use 3-4 times easily
1 - 20 of 23 Posts
