i think this subject comes up a lot. this link may be useful: SAE 30 vs 5w30: What’s the Difference?
This is backasswords. Viscosity is resistance to flow so higher viscosity fluids have higher numbers.To grade oil, the viscosity/weight (how easily the oil can flow), is used. The ratings go from 0-60 with the lowest numbers representing the thickest (most viscous) and the highest numbers representing the thinnest (least viscous) oils.
It does sound wrong, the number before W represent viscosity in winter so 10 is more viscous than 5 and thinner than 20, but according to the remark in the link 20W is "least viscous" oil which does not make sense.This is backasswords. Viscosity is resistance to flow so higher viscosity fluids have higher numbers.
Many off brands often do good.We could discuss oil until the cows come home.
Use a quality oil (no off brand junk), and check it often to keep it full and run whatever machine that it is you want to run.
Multi Viscosity 5W (W for Winter) and 30 weighti think this subject comes up a lot. this link may be useful: SAE 30 vs 5w30: What’s the Difference?
I meant more of the stuff you see in the dollar store or convenience store that is a brand that has no sense of quality. I remember some kind of issue with motor oil bottled and sold by a dollar store that was of such poor quality it barely met any kind of standard.Many off brands often do good.
I've heard nothing but really good stuff about Amazons full synthetic and I've been tempted to use it a few times.
Save your breath.
All oil is 10w-30.
Additives are put in it one way or the other.
Additives wear out, but the base oil remains.
A lot of dollar store stuff are items that were rejected for QA, contamination, etc. that somehow managed to sneak back . . . I absolutely refuse to ever buy food at one since recalled stuff has been known to show up there, and I am very leery of everything else . . . It's dirt cheap for a reason, and nobody ever went broke buying a single quart of oil for thier blower . . .I meant more of the stuff you see in the dollar store or convenience store that is a brand that has no sense of quality. I remember some kind of issue with motor oil bottled and sold by a dollar store that was of such poor quality it barely met any kind of standard.
Stuff made for amazon is probably made and bottled in the same plant as some of the bigger name products.
Additives are added that make it 0,5 or whatever. How do you think it's done?I suppose..........
Except for all of the oils that aren't 10W30. Like 0W30 and 5W30 and SAE30 for example.
