when I releas the lever I here the screach which I would bet is the brake but is that normal? I've heard the same noise on other blowers so it seems to be common
I'm sure you must mean the other way around releasing the lever allows the auger belt to be loose. The screach noise lasts just a second after I let go of the auger lever.Releasing that lever allows a belt to get tight. I bet your hearing that belt. Does it keep up, or does the sound last just a second?
