I mistakenly added too much oil to my Cub Cadet 2018 2X 26’ snowblower. After a bit of research, I found out that there is an anti-siezed fluid that can be use to clean out the oil in the engine which has reached the spark plug. I’m hoping but not wishing that anyone had this issue and knows what fluid that can be used and maybe give some tips on how to get this fix started.
quick issue details: after over flowing the engine with oil, the engine won’t start even after removing the excess oil. Noticed after cleaning the spark plug, and try to crank start the snowblower, the spark plug becomes again covered with oil, hence the engine won’t start. I hoping no greater damage is done to the engine as it has not fully started since I messed up.
Thank you all in advanced.
