1 - 10 of 10 Posts
Newbie here, I need to order some replacement shear bolts for my JD 47" blower that is hooked up to a 400 series tractor. My local JD dealer is no more and I'd like to locate some online if possible.
Can anybody help?
Thanks,
Stu
Surprising as it may be, I've done a search and have not been able to find the part you need,
but maybe someone else can help you locate a online store that sells them.
I suppose your John Deere dealer would be willing to order some for you?
Wow, Thanks for the quick reply. My local JD dealer went out of business several years ago. I was hoping I could get the info without having to drive 40 miles to the next closest dealer. Why wouldn't JD put a part number for these very necessary parts in the info book privided with the equiptment? Maybe so they could sell a parts book...
Stu
Check your local hardware store. The two in my area carry them. Take an old one if you can to match them up.
OK that's an idea, I thought they had to have certain tolerances to avoid damage, and to make sure they work as required.
Stu
As long as you get the same diameter and length they should be the same or close enough to not matter. My store even has them with grooves just like my original bolts.
Great, where'd you find them?
1 - 10 of 10 Posts
