Make sure there is a little play(you can jiggle a little back and forth) in your shear bolts...nothing says broken worm gear case faster than a frozen or too tight shear bolt.
Thanks for the timely tip!:)
i will have to remember to check mine
Do check your manuals as well some shear pin set up might be different
depending on type and model but I believe most should have a little play.
