So yesterday when I was out working on the new Deluxe 28 my neighbor sees me looking at the auger area and I said "look bolts and not sheer pins" he goes to explain that he only uses 5/16" grade 5 bolts in his auger as he had a failed brass gear using the factory sheer pins that didn't break but the grade 5 bolts always broke. Now why is it that his sheer pins didn't break? I need to get new pins but yes I have put bolts in blowers in the past and those did not break on mine and damaged the gear. Don't need to go through that again if I do not need to.
Grade 5 makes me cringe, gotta say.
Grade 5 is medium strong... Equivalent to Metric Grade 8.8. But shears well unlike the lesser grades since it is medium carbon steel, quenched and tempered.
I'd use what manufacturer says, and if they are bolts, do not overtighten them. My tractor blower specs grade 5 fully threaded 1/4x20 bolts. Grade 5 makes me cringe, gotta say.
Yes, what every they spec is the wise decisions. Unless you have a Cub Cadet 3x. They now spec Grade 8 bolts on the impellar shaft due to too many complaints of the shear pins breaking. There are long threads on this for anyone who is curious. If I had one of those machines I would stay with something softer and protect the impellar shaft and related parts. Just stop running over rocks and junk under the snow. Or get a different machine.
I had a Toro that spec'ed Grade 5 bolts. No grooves or anything special. Just an of the shelf bolt. Toro says their auger gear box is tough enough to handle the shock.
There are a variety of configurations speced on machines out there from custom pins with grooves to off the shelf grade 2 or grade 5 bolts.
