Model 1695822
Serial 2014639210
The electric chute deflector doesn't work. I'm told that at some point it was intermittent. But now it does not work at all. I did some basics but don't know what the next move is.
I put 12V directly to the motor and it works fine. There are two wires going to the motor. I disconnected the connector and put my multimeter on it. When I actuate the switch, the circuit closes and I get 0 ohms.
I removed the switch and connected it to the other harness for the motor that moves the chute left and right. It works perfectly.
So the switch is good and the motor is good. Maybe some sort of relay?
Thanks
Serial 2014639210
Thanks
