Based on the information that you just provided, I think a typical 160cc or larger single stage snowblower would be fine. The Toro 518ZR at 99cc would probably be fine for most of the snowfall, but it would struggle a bit for the EOD. Most of the time, EOD is a non issue if you can get out there and take care of it early before it refreezes.
I would look for a Toro 621QZ, 721QZ, either new or used depending on your budget. You'll have to weigh the savings in used snowblower versus a new snowblower with a new set of paddles and scraper and a warrantly. The Toro Powerclear snowblower is a very common snowblower which parts are easily available. I have the Toro 421QZE that is a 2009 model with the Loncin engine and it has been running great. I have total confidence in this engine lasting a long time with proper maintenance. I think the chassis and other things will rust out before the engine dies.
The Honda HS720 is a good snowblower too. I think it looks nicer and higher quality than the Toro, but in real operation, I prefer the ergonomics of the Toro. I have the Honda HS621 and I think the Toro is just quicker and the Quick Chute is just more convenient to get things done.
These are all good machines. You just have to try them out and see which ones suites you better.
