1 - 1 of 1 Posts
Manual says give the gearbox 5 shots of '00' grease. I had read somewhere that there is a possibility that applying too much pressure when doing this could possibly blow out the gasket. How to know if I'm applying too much pressure? Also, I've seen '00' grease from sources other the Snapper which is a lot less $. Are all '00' greases the same?
Thank You.
1 - 1 of 1 Posts
