My Snapper I5240 has an auger that wont stop when the handle is released.
I have installed a new rubber brake, adjusted belts pulleys and activation springs. This has failed to solve the problem. Since it"s a safety issue I'd like to have it solved before the first snowfall.
you might have the wrong size belt on there. where did you get the belt from????? it has to be fractional HP. not from a auto store. ALOHA to the forms..
Either the belt is too small or your idler pulley is not fully retracting. The idler pulley should not be under the engine pulley when the auger is disengaged. Make sure the springs that pull the idler back are correct and that there is no binding. Also make sure there is slack in the auger engagement cable when disengaged, if there is no slack in the cable it will cause the auger to not disengage. Try disconnecting the auger engagement cable or rod from the engagement handle. Check the manual for the correct belt size and get a new belt. You may have to re-adjust the idler with a new belt. it should be 1/2" x 35" as far as i can tell.
just get a 1/2 inch x 35 inch belt. That is the correct size. here is a link to a kevlar belt for less than 5.00 plus shipping. Since you have to pay shipping anyway i would get a spare. A33K - A-SECTION KEVLAR (K-PLUS) V-BELT
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Snowblower Forum
461K posts
34.5K members
Since 2010
A forum community dedicated to Snowblower owners and enthusiasts. Come join the discussion about brands, maintenance, reviews, troubleshooting, repairs, accessories, classifieds, and more!
