2016 Freightliner 114sd SnoGo TU 3
Vin: 1FVAG3CY2GHHH0542
5,900 Miles
409 Hours
Cummins 8.9L L6 Diesel Allison Automatic
Snow-Go Wausau TU3 Snow Blower Powered by additional Cummins Diesel Engine. Snow plow truck was government owned and maintained since new. This snowblower truck is perfect – like new condition. Could be used as a snow thrower truck for airport runways or other large areas, like sides of highways to throw the snow up over a wall. This snogo snowthrower snowblower truck is ready to work, everything is like new. It will drive down the highway at 65 mph +
Snow Thrower, 4×4, Oshkosh
Wausau, Loader mounted snow blower, Maqueen, truck mounted snow thrower, airport snow sweeper, highway snow blower
More - The chassis is a 2016 Freightliner 114sd - the chassis is first lifted and 4x4 is added then the transmission is modified and the snowblower and its separate Cummins engine is added with all of the other components.
This compact two stage, full mechanical auger type blower head is suitable for all snow conditions, and ideal for spot-casting/loading of snow. Its three 18” horizontal augers feed into a 41” impeller. The cutting width is 102”, the blower height is 60”. Separate shear pin protection for both augers and impeller.
Power Package
Blower engine options range from 350 hp to 425 hp, providing outputs up to 2500 tons per hour. Power is transferred from the engine to the blower head either by chain and/or gear drives. All drive train components are engineered with ample built-in safety margins to assure reliability and longevity
Carrier
This blower package can be installed on a conventional all-wheel drive chassis.
Airport Truck
FRINK
WAUSAU•EVEREST
HEAVY-DUTY SNOW & ICE CONTROL
Tyler Ice
EVEREST
SNOGO
Snowdozer Snodozer
Everest Equipment Company
View more -
Snowblower Truck For Sale
