1 - 2 of 2 Posts
Looking to buy a snow blower attachment for my #1440 Cub Cadet tractor. It is discontinued but the attachment # is: 190-451-000.
thanks!
thanks!
I realize it might be a little late in the game to answer this question, but you can use either the 451 or 551 without any modification. Both are 45" 2-stage blowers. In fact, a QA42A or QA36A would work as well. Those are both single-stage blowers built for the IH made Cubs a little older than your 1440 model, but they'll still work well enough as long as you keep your rpm's high.
there's a couple cub cadet forums, two in particular, that are VERY informative and have great members that may also be able to help you source a blower for that cyclops.
Do you have the manual lift or the optional hydraulic lift on your 1440? If it's hydro, a 451 or 551 will not be an issue. If it's still a manual lift, do yourself a favor and make sure you buy a spring assist with the blower, otherwise your arm will hate you by the time you're done. When sourcing a blower, be sure to get the lift bracket if you have the ability to. Otherwise, you'll have to go buy one of those as well and they're not super easy to come by.
Good luck!
1 - 2 of 2 Posts
