1 - 2 of 2 Posts
Looking a crank shaft for this unit also brake housing sprocket that attachs on to crankshaft that drives the chain :rolleyes:
good news is that is a great snowblower and an even better engine. bad news is those cranks, if you can find them are in the area of $300.00
The clutch sprocket is readily available. just do a google search for... "3/4 keyed shaft centrifugal clutch sprocket" and you will find them, just make sure of your shaft size and chain size.
I would look for a complete used kohler engine. it would be cheaper. you could change to any brand engine on that snow blower, only things that might change are the bolt pattern to mount it (drill new holes), a longer/shorter drive chain, and the flat steel mount on top of the motor for the chute control. those are the only items connected to the engine on that machine.
1 - 2 of 2 Posts
