1 - 2 of 2 Posts
Hello I just joined the site I live in northern minnesota. You have a great fourm with lots of good info. I have a 69 simplicty snow away 5 hp 2 stage blower anyway i bought it 2 years ago for 25.00 and it was a good runner. Last year it started to knock and i shut it down immediately. I opened the side of the block and the the rod bolt retainer had broke .:( I cleaned up the crank bought a new rod. I was wondering can i just do a light hone to the cylinder to make new hatch marks and use new rings or should hone it to .010 and use a new piston?
Any help from you guys would be appreciated.
Engine repairs
I'd gauge the next step based on the condition of the piston, rings and cylinder. If the cylinder in particular is good: no tapering, no out of round and no wear ridges then I'd lean more towards cleanup and reassembly. If on the other hand the cylinder has issues then I'd look at boring/honing it first. Same thing if you had any marking/scoring of the cylinder from the broken rod, a broken ring or ring landing on the piston.
If things are in otherwise good shape, why introduce any additional variables to the mix than you have to?
My thoughts.
1 - 2 of 2 Posts
