I have an ariens 136cc 20in snowblower withLCT engine. When i removed cover to bleed carbureter i broke some leads on harness to on off and ignition. I replacedthem then realized i had leftthe ground off. Blower started, but would then not shut off. I repairedground but am still having same problem. Ideas?
No throttle on those engines, Will need to pull side cover off, I worked on one with same issue. This one had a broken wire connecting to a spade connector, Wire was still crimped but wire was not connected.
