1 - 10 of 10 Posts
Just purchased a new toro 928 OHXE power max (38801) When im in first or reverse 1,2 im getting a faint squealing noise. Every other gear is fine. Could it just be where it is new or is this an adjustment issue? If i lift the rear wheels and disengage them with the power steering. The noise stays.
I am guessing it is a new issue, does it make the noise in both reverse gears? My new 1128 has not made that noise but I wear hearing protection.
Hello ! Sometimes when belts slip you get a (same as car) squeal, so maybe double check the belts you may not have quite enough tention on the drive belt for the traction. might not hurt to check the auger belt as well while you're in there. If it was put together at a dealer I may be wrong, but big box store employee may not have adjusted it correctly. Just a thought, let us know what you find :)
You may need to adjust your traction cable and for that look on page 22 of your operator manual for the correct setting then the squeal should disappear. What happens is not enough pressure is applied on your friction disk to the disk plate. Good Luck
It wasnt purchase at a big box store. Its a Toro dealer thats also sells bombardier. I did adjust the traction cable. But maybe not enough. The cable pulls on the left side of the flex plate which would start at 6th gear. Quite possible that its not enough flex on the right side and the friction wheel is slipping???
The left hand cable is the one to adjust for pressing the friction cable against the disk plate and to avoid it squealing. You may want the dealer to adjust it properly but that is your decision. The rod threaded at one end and fastened with a spring pin at the other is to adjust where your friction disk will contact the disk plate going left of center for forward speeds and left of center for reverse.
Good Luck
True indeed, may be the friction wheel disc slipping, or the belt on the pulley. That's a machine you will enjoy when it's straightened out. Should be an easy fix.
1 - 10 of 10 Posts
