1 - 1 of 1 Posts
Looking to replace the belts on my st504 model 932006. I believe the drive belt is a 72106 belt and the auger belt I believe is a 72107. Right now it has an ariens 72106 cogged belt for the drive belt. Being that it's an actual ariens belt and looks really old I'm thinking it's probably the original. The auger belt has no numbers on it but it is a cogged belt. From my research I believe the auger belt should be a 72107. Just want to confirm this and also make sure that I should be using cogged belts on both. That's how it is now but I'm thinking maybe the auger belt has been replaced at one point seeing as how there is no markings or numbers on it. So does anyone know if these belt numbers are correct, and should I used cogged belts on them?
Sent from my SM-J327T1 using Tapatalk
1 - 1 of 1 Posts
