1 - 2 of 2 Posts
I just PM'd someone else this info so I'll post it for you, mines a 291cc but I'm sure the steps are the same:
You need to remove the muffler bolts/cover, pull off the choke knob, remove the primer bulb cover bolts which you don't have to remove the cover entirely but just pull to one side to access the rewind bolts if I remember correctly. Pull off the fuel shut off knob and remove the bolts for it's cover and then remove the rewind bolts which in my case involved removing the fuel tank bolts to access one of them. Once you pull off the rewind or pull out and shift it to the side like I did then you'll have access to the two starter bolts. It looks worse than it is, just take your time and you'll figure it out.
1 - 2 of 2 Posts
