so, I am dismanteling an old seized tec 8hp for fun, and for my own knowledge, one of the 2 pulley set screw is stuck, i put wd40 in in, but it just doesn't want to move, what should I do?
I don't have acces to a torch or something to heat it up
Also good for starting charcoal/briqs for a bbq 😁go buy one 15 bucks
I don't think that is the case, as I was able to remove one with wd40 only, no heatBe aware that someone along the line may have had it apart and reinstalled with loctite. Heat is the only way especially if they used the high strength product. I assume it is recessed so heating followef by pb blaster or kroil. Let it sit and penetrate. Also when I worked in electric motor shop sometimes TWO setscrews had been installed with locktite on critical assemblies.
as mentioned vibration may work. and patience. I use a brass hammer and have removed almost everything by vibration thru hammering. just be sure not to damage the set screws.I don't think that is the case, as I was able to remove one with wd40 only, no heat
While you can get a complete propane torch kit for $25ish, I would recommend getting a MAP torch kit; hotter and more useful. About $50ish. (And, of course, higher in Canada.)go buy one 15 bucks
Over the years, when faced with these problems and knowing a tool I did not own would solve the problem, I went ahead and invested in a good version of that tool. Buy a cheap one, and you will usually have to replace it. It's funny how these 'one time use' tools get used again when you are in a pinch. This is especially true for the commonly used stuff. How many guys here do not own a torch?*so it basically paid for itself the first time I used it (it has since paid for itself many times over).
place in sun ,shield with dark cover allows sun to heat upso, I am dismanteling an old seized tec 8hp for fun, and for my own knowledge, one of the 2 pulley set screw is stuck, i put wd40 in in, but it just doesn't want to move, what should I do?
