1 - 20 of 25 Posts
I accidentally ran over the Sunday paper under the snow and it is wedged in the impeller. on my TORO snowthrower I cut away as much of the paper as possible but cannot get it free. Do I need to disassemble the impeller and how do I do that
:welcome: to SBF Frustrated
What model # ??
If it's still frozen might be time for a hair dryer to soften it up so you can pull it all out. Check for damage before firing it up and before using it if you get that paper free.
soak it with warm water..turn it to mush, should be able to pull it out that way.
get some big pliers, and just pull out little bits at a time until the whole thing is loose enough to come out..
you could also try a small saw, like this:
https://www.homedepot.com/p/Stanley-6-in-FatMax-Jab-Saw-20-556/203730285
that should rip it up nicely..
I doubt you will need to disasemble the auger..just hack away at the paper, it will come out..
See, many of us don't have that problem because we either don't get the paper or get it online! Or we have a much better paper carrier!
You have to keep trying to remove as much as possible, use a utility knife, a hacksaw blade, a saw, keep sawing away.
There's been many suggestions before, over a dozen do a search for newspaper.
One of the things suggested is using a 2x4 to pry the impeller blade or auger rake, but there were many other good suggestions. It all depends upon the situation. Maybe you can even burn it away with a propane torch but then you are also burning the paint away. On some machines it's very easy to remove the sides giving you better access to the impeller.
If it is that jammed up in there, you just might have to. otherwise post some pics of this mess. so the masses here can have a looksee at it all. ALOHA from the Paradise City.:smiley-rpg027::smiley-rpg027::smiley-rpg027::smiley-rpg027::smiley-rpg027::smiley-rpg027:
If you're not already beyond the thawing stage, a Hair Dryer can be useful in accelerating that process; maybe with a blanket put over the scoop to retain some of the heat.
Been there, done that on my Toro 521. Try to get the impeller to go backwards . . . usually that will free things up.
Already soaked. Guess I just need to keep hacking away
Thanks
if you could get it into the garage and throw some heat on it , maybe a hair dryer or portable heater and unthaw. then use some big channel locks or something similar.
very common problem around here. newspapers, tarps, pine cones, firewood, slippers, etc. it all comes out without disassembly with patience. however real fine stuff like tarp remnants, wire, string , etc. may need disassembly.
after you clear it, make sure your shear pins are still okay. or nothing was bent.
Get yourself a newspaper tube and tell your newspaper carrier they will get an end of year tip if the newspaper is always placed in the tube. Our local newspaper will give the subscriber a free newspaper tube on request (and deliver it to your house).
It took me forever to get the wife untangled from the auger. The next time I'm going to use a wood chipper. ;)
It's a joke son, a joke I said.
not funny....... you have no feelings for what the snowblower went through, and then to add insult to injury you compare it to a wood chipper........not cool man
He could also take his shear pins out and start backing it out that way as well. Thats how i got a door mat out of someones snowblower......................
Yup, something to be said for 'pull the shear pins, and back it out with a large wrench on the augur shaft' . . . Not subtle, but effective . .
I had this happen on my old MTD,it bent my auger.But with patience ,I got it out one bit at a time ,the paper was not readable lol.
Terrible. This is "Snowblowerforum.com". Thou shalt not take the name snowblower in vain. And you mix it with an unholy wife.
1 - 20 of 25 Posts
