When you use a little regular dino grease, it hardens after time, after a long long time, as if the volatile compounds evaporate. I haven't used synthetic grease for as long as I have dino grease but my feelings are it won't harden. This is only one reason why I use synthetic.
I've been using the brand Never-Seize since my father introduced me to it in the early 60s, and have used it since on anything that may get stuck on by rust, heat, or torque including car lug nuts, muffler & exhaust bolts.
I will still use Never-Seize where heat is involved because of the high melting temperature. If synthetic doesn't harden after time and cause sticking, tightness, I've been using it instead of Never-Seize where heat is not involved, snowblower axles, skid shoes and scraper bar bolts, sliding friction disk hex bar.
