I have a machine to repair with a Tecumseh 5.5hp, I KNOW they worked on the carb and pretty sure the linkage and spring going to the governor are in the wrong spots but not sure which they should be in on the 5.5hp, Does anyone have a pic of the linkage on one that works correctly.
Thanks
Dauntae
I may a T5.5 outside but it's pouring so later. If I recall as I had the carb off, I think it uses the same holes as the 5hp.
That's the standard 5hp, 640084b, but get the adjustable one 632107, preferably also with an aluminum fuel bowl however yours will swap out.
