1 - 20 of 36 Posts
Good morning,
I have a friend's Ariens 1332 Pro that I "volunteered" to fix for him. It seemed like your typical" I haven't ran it in a couple years" issue so iInitially I disassembled the carburetor and cleaned it but then determined it was too far gone so I replaced it. The machine starts now but I am having issues with very high idling and am suspecting the governor. Just wondering if you guys can tell by the short video clip if/how I would adjust the governor on this particular model as I haven't dealt with it before. There appears to be a small screw on the bottom linkage that affects the governor. I attempted to adjust that in and then/out but it doesn't seem to have affect. The other thing that causes concern is when I adjust the speed lever it doesn't have any affect on the motor even though the butterfly is moving on the carburetor. To further make things complicated, when the Engine is running and the Idle goes real high, if I attempt to manually move the throttle plate Away from the idle screw(which would increase speed) just to see what happens the speed actually decreases and it eventually stalls. I apologize if this was a confusing description. Hopefully the video clip Will clarify. As always thanks again for the help! PS it is a Tecumseh 13HP OHSK-130
Good morning,
I don't see the attachment to the video. I think you forgot to add it. Can you add it please. Thank's.
I apologize I'm having trouble posting the short video clip . I'm only able to post this pic which prob won't help much . I will try to post the video if possible .
Is it an adjustable carb. I can't tell from the pic. If so what did you set it to. I believe it should be 1.5 turns out from seated position. Unless the governor has been fooled around with or broken previously, it shouldn't need attention.
It is a non adjustable carb. I have no way of knowing if someone messed with the governor before me . Im only leaning that way because the rpms are pretty high (seemingly to high even for an out of adjustment carb or idle screw issue but I could be wrong) Unfortunately I still cant upload the video I think because Its from an iPhone in .mov format. Sorry I know its impossible to assist without more info I will keep trying.
Easy to tell if the Governor is Toast. Run the engine at 3/4 throttle, and see if the governor arm is applying pressure by manually pushing the arm away from the carb. No Pressure=Bad Governor. Otherwise, You should be able to get it working correctly by adjusting the governor and the Throttle Screw.
Governor parts inside the engine rarely go. And governor's never go out of adjustment if they are set correctly from the start. And you always should buy an adjustable carburetor.
That said, governors are easy to adjust, loosening the nut, pulling it all the way over while holding the throttle on the carb to high speed. Check out YouTube.
After that I think you may have the carb linkage in the wrong hole on the carburetor, unless you have a bad carb which is rare.
Thanks for the help , I will try the 3/4 throttle and see if the governor has resistance , hopefully it does ... I replaced a blown apart governor on another machine last year . Not the end of the world was just hoping it was the bad carb .....
I've Replaced Quite a few over the years, sometimes the plastic gear goes, or the weights break away. Let us know what you find.
Finally figured out how to post a video......I was able to upload to youtube so hopefully it will clarify what I was trying to describe. It appears as though the linkages are correct and not bent but more eyes on it the better , Thanks again all!
If you look at the throttle plate on the top of the carb, do you see there's a screw with a spring on it, that stops the plate at the end of its clockwise (viewed from the top) rotation?
To me it looks like that screw is adjusted in way too far. I'd back it out about 2 turns and see if things improve. Maybe even 3. That screw controls the idle speed and as you back it out, the RPMs should drop.
If that doesn't help, see if you can get a video doing exactly what you did in this video (moving the throttle lever through its range) but with the engine running so we can see how it's responding to the throttle.
If the above does help, adjust that screw so the engine idles at a reasonable speed with the speed lever in its lowest position and you should be good.
Also if you messed with the adjusting screw on the speed control lever, you might need to get your hands on a tachometer to get it adjusted correctly. That screw sets the engine's RPM with the lever at it's "high" position and typically should be set so the engine runs at 3600 RPM max.
A bit of an update sorry for the delay,
Since last post I replaced the throttle plate mechanism as it seemed to be bound up a bit and was a pretty inexpensive part to replace. This seemed to help a bit but still have some governor issues.....I think. I attached 2 short videos that will hopefully illustrate what I am going ton try to describe. (Just to refresh ...I have replaced the carb with a factory carb (non adjustable )like the original.)
The blower starts and seems to run fine. it will blow snow for a few seconds sometimes up to about a minute but as soon as it hits a substantial load it dies. I incrementally adjusted the governor both directions the furthest point . It seems to help with better engine speed briefly but the governor still doesn't seem to kick in when I hit snow.
I then tried to manually open the carb where the governor normally would under load, the RPM increase briefly and then the engine dies. Normally I would suspect a fuel issue but given its a new carb /fresh gas, etc I dont think it is. Please let me know if Im missing something .Thanks again!
Hey Twes.... I just saw this post....on the first pic from 2/2?? the linkage is on wrong. From the throttle lever to the governor, looks like the arm flipped down 180* that lever should rest against the little high speed adjusting screw. The video's don't show if it's put back correcctly, but it doesn't SOUND like it. Please double check that. GLuck, Jay
GEvening Twes, Again, that may be a false lead, but quick and EZ check/Fix. The first pic shows it, but neither videos show that angle. BUT, that symptom describes your problems exactly. GLuck, J
Discussion Starter #16
So I replaced the throttle lever plate and replaced the linkage to the governor as it was on the original. I double checked from a repair manual (at least I think I did) to ensure I had it correct. I snapped a pic with the new one lemme know if you still see something amiss.
ELaw I missed your post sorry, I did notice the idle screw to be in to much and adjusted it to be at a more reasonable rpm. I will take a video of the throttle lever going through the ranges while running but prob unfortunately won't be able to for a couple days.
Any idea what would cause the machine to die when it comes under load . The throttle plate opens up as if the governor is attempting to compensate for the load but then shuts right down........ Will start right back up but as soon as it hits a considerable load same thing......throttle plate goes wide open then engine shuts down...... Thanks again for all the help.
From that pic it looks like the linkage is set up right, although as far as which hole the wire should be in at "3", I'm not sure. It's probably okay the way it is.
Re the engine dying under load, question: when you tested, was the engine 100% totally completely entirely fully warmed up?
Newer engines run pretty lean and you can't open the choke fully until they've got plenty of heat in them. Does it run better with the choke one notch from the open position? If so, I'd say run it that way for 10 minutes of snow removal or at least 15 minutes of idling/light load then see how it runs with the choke off. If it's okay under those circumstances, what you're seeing is probably normal.
The fact you're not running the cover over the carb might have a small effect on the above too, since the carb will be getting colder air than it would if the cover was installed.
Also it sounds to me like it's starving for fuel when you go to rev it up..... it's not backfiring like a lean condition, so maybe the needle or float is not open enough to allow enough fuel in.....? You might try adjusting the float lower if its no one of those fixed non adjustable ones...... but, yeah, don't adjust anything until it's a full operating temp so you know that the choke needs to be open full, and see how it acts and adjust accordingly. Make sure the the needle rides up and down easily and isn't slightly sticking - that will make it intermittent and not smooth also. Some of the floats have a spring that must be placed correctly as well - which helps keeps things smooth.....
Discussion Starter #19
Thanks again for the responses . I retried all the conditions and made sure it was warmed up when trying to bring under load , unfortunately same results, runs fine idles up/down with throttle lever but when I hit load it dies. I made a quick video of how the engine behaves when I throttle up/down and also how the engine dies when I hit snow.
I dont think its such a thing but could the governor be partially gone? I always thought its either blown apart inside or not but mine seems to be trying to adjust especially when I increase the RPMS (like its supposed to) but then can't compensate under load ............
That's not a governor problem you're having there.
In the video where you push the machine into snow, you can see the governor opens the throttle to try to compensate for the engine slowing down. So the governor is doing its job. But when the throttle opens, the engine dies.
That's most likely a carburetor problem... I'd say most likely the main jet is too small (maybe they installed the wrong one at the factory?) or clogged. The float level being way off is another possibility.
A less likely possibility is an air leak between the carb and the engine. Maybe the gasket where the carb attaches to the manifold, or where the manifold attaches to the engine? But usually such problems cause more trouble at low load than high.
1 - 20 of 36 Posts
