Hi, hello, im Mike. Please, can anyone help with this motor? Trying to find carb linkage and spring(s) and their configuration. I imagine i can recreate the rod between the governor and carb, it is there just about to wear thru. Really like to know the aprox age just for kicks n grins. It has been repurposed to a log splitter, retired sitting for several years and being resurrected, did start with an iv fuel bottle, ran poorly as expected. Cleaned carb an jet will do another fire shortly. Someone had poorly rigged the throttle and choke linkage, wish it was a spring hold choke but it needs a cable. Looking for which carb/choke remote will work.the mounting bracket wth spring return is mounted on shroud for remote cables. Im probably in the wrong area but had to start somewhere thank you
Discussion Starter #2
Yes I am positive it is a 3B at end of model number. Have been checking parts views of other models. Oh in need of air filter and cover too thanks
