1 - 2 of 2 Posts
Can I use a 34923A gasket in place of a 36451 for a hmsk110(358cc) the 34923a gasket is for (318cc) they both use the same head according to what I've found any help is greatly appreciated
We would have to know all the engine numbers on both engines to help cross the part number over. You might want to fit one gasket up to the other to see if they will match.
Its possible it might work but it could be different. There is a difference in the bore or stroke from the displacement difference but it might be the same gasket with the same head. It could be different though because of a bore size difference with the gasket "Crush-ring" if it uses one.
Tecumseh are getting a little bit harder to get parts for since they went out of business, but there are still a lot of places you can get a lot of the parts for them at.
1 - 2 of 2 Posts
