Was running fine before a prolonged headstand (days long) now it won't stay running. Will start for a quick second or two when primed but won't keep running. Something stuck somewhere? Do i have to take it apart?
It's on a 8hp Snapper HD 8265.
By headstand, do you mean having the blower tipped up into the service position? I guess if the fuel was left on you could have a block full of oil and gas. Check the oil level.
Try tapping the float bowl with a screwdriver handle or remove the bowl to make sure the float is not stuck in the up position.
