Was working on a cast iron gearbox and had a heck of a time keeping the worm gear key on the impeller shaft in place as the worm gear is sliding in place as the auger axle is introduced through the side ......
Solution: applied a little gel super glue to the key, put it in place and did a dry run with the impeller worm gear ..... then marked the worm gear for the keyway slot on the teeth .... kept the key in place and easily lined up the gear as I inserted the auger shaft. Just no space in a side cover cast gear box, but very well built.
